I've got $2000 to spend on a lighting kit for interviews.
Any recommendations? Lowell, cool lights?
Thanks,
Doug
Then there are the kind of hybrid lights like the CDMs that Richard sells. They seem like a great idea although I have not actually used one. A 150 that puts out daylight and has the output of a 650 for $399.00 sounds cool but this only makes sense if you are going to build an entirely daylight kit.
HTH
Dan
For the most part you're right Dan on the last comment but we do give the choice between a 3000K and a 5400K bulb when you buy the fresnel so it is possible to blend this with any legacy tungsten you have and have a "cool light" version of a fresnel that gives real hard light with no compromises (and hardly any infrared like with tungsten) other than that you have the ballast with the unit which, although it is small and only weighs less than a pound, it is one extra item to carry around. While most people choose the fresnel with daylight, there are a few that get extra 3000K bulbs, just in case they ever need them.
I've seen your comments about preferring tungsten to fluorescent for how it makes faces look before and I would really be interested to hear what you think about the daylight or tungsten CDM 150 unit on "faces". To my eye, its tough to distinguish the 3000K CDM bulb from a tungsten unit.
Hi Richard:
Thanks for the education on CDM. I am not familiar with them although I have used HMIs a lot. I was not even aware that you had tungsten balanced bulbs for them, that is great. It makes the instrument much easier to integrate into an existing tungsten workflow. I am sure at some point I will buy one from you to try it out, but I have to worry about acquiring an expensive location monitor first. With the strike still going and the economy over here slipping into recession, I am slowing down spending quite a bit too, things seem very unstable right now in production.
Hope all is well and that you are enjoying your RED!
Dan
When you say "Chiaroscuro pools" is that just like doing a slash of light or multiple small spots (someone mentioned one light and a cookie with lots of holes in it in another thread for this) on the background so it isnt so darn bland?
