soren k jensen
Moved from cinematography:
I use an MPIC 35mm adapter on my HVX to work with Nikkors and lensbaby. No problem, niice stuff. BUT, I hope to also use Large Format techniques like lift, drop, swing, tilt of lens in relation to the film plane. I have tried several large format lenses, enlarger optics, Nikkors with Perspective Control and what have you. But for all of them, I get serious hotspot/ vignetting problems as soon as I move the lens more than a few degrees, even with LF lenses that have a large image circle. The only lenses that somewhat work , although with a result that is not exactly crisp, are magnification loupes.
Any ideas on how to work with the desired LF techniques on my HVX?
(Admins, you may delete the post in cinematography)
