Could people please weigh in on the major differences between these two adapters? I see that the M2 ranges between 999-1300 while the Letus35 starts at 300. I appreciate any help in researching these two pieces. Thanks
the letus35 is a static adapter, meaning the focus screen/GG does not move. What does this mean? If you sotp the iris of a 35mm lens down to passed F.4, you will notice that the grain is apparent. The only way to get rid of this is to vibrate/spin/oscilate the GG, which is what the M2 adapter does.
The material used for the GG is slightly different so you get a different light pass and bokeh.
One of them is much more expensive and requires batteries, but you get much more lattitude with the M2 for reasons of having a wider range of F stops whiel maintaining a clean image.
there are other things, but meh.
i picked up an Ifocus and i couldnt be happier, cheaper than the M2, around the same price as a letus and it came with a lens!
I would say the biggest difference between the two would be build quality, as I have been very happy with the image quality of the letus, although the corners do tend to get a tad soft, but not an issue when shooting 2.35:1 or even 1.85:1. When I upgrade my camera, I will most likely be upgrading my 35mm adapter, but the Letus has served me quite well, although it is a little "gorilla" looking compared to the M2
