Tim Naylor
Where did you buy your lomos? RAF is always sold out. Any leads?
Soft? Not really sure what you think you're seeing. Of course putting any lenses on a 35mm adapter in front of a HVX isn't a good way to evaluate sharpness and resolution, but these lenses easily outresolve the HVX chips.
These Lomos are the high speed variants from the late 80's and are plenty sharp- especially on film where I've intercut them seamlessly with Mk3 Zeiss superspeeds.
The main difference is the Zeiss primes have a bit more contrast especially wide open. In regards to the standard vs high speed Lomo lenses my experience has been that the standards are only sharper at T8 and above which makes sense since the high speeds are optimized for T5.6 and lower.
What you're noting may be the difference between the EX1 and the HVX or perhaps you're used to the detail cranked up in camera to add sharpness. My HVX detail is 0.
Anyway these lenses work fine for me. In my own less than scientific tests they equaled if not exceeded my Zeiss Contax primes in resolution. For whatever that's worth.....
Ok so I shot a quick and dirty test with a few of my Lomo primes. I went in ascending order from wide to telephoto. Shot very fast under changing lighting conditions so the exposures aren't perfect. No CC.
HVX 200 @ 720PN
180 shutter
56K preset WB
Lomos
18mm t1.6
35mm t1.6
50mm t1.4
75mm t1.6
100mm t2.2
Zeiss Jena MC 180mm f2.8 (medium format lens with OCT-19 adapter)
All lenses shot at 2.8 except 35mm @t2.0 and 180mm @f5.6
The last shot with the 180mm is to demonstrate the zoom capabilities of the Lex. I was able to zoom from around 74 to 99 with no noticeable image degradation.
More footage to come when I have time. Maybe even something dynamic with music!
Enjoy.
www.iandudleydp.com/LX-LOMO-TEST.mov
