Letus Economy + Indirails + Geardear Support
MalcolmOng
Hey guys,
My geardear lens support arrive today, and it seems great - looks and feels quite solid. But i have a problem - at it's lowest adjustment level, it's still too high to support my letus economy and indirail getup. Does anybody have any ideas on how i could go about fixing this? I was thinking of welding a quick-release system on top of the indirail plate...that should add enough height. Anybody have any ideas otherwise? Does anyone have a similar getup?
I'm waiting for my Extreme so that I can use my support that I've made from Cinevate Universal 15mm blocks. It is galvanized to make it black, not spray painted. And also rubber padded to absorbs the vibration from the motor of the adapter
The Geardear support is good, but over time it will start peeling especially the ring, the ring is very thin and you have to be careful not to bend them.
Here is my solution. It is low enough to mount any Extreme or Economy to a indie or cavision rail set. The minimum height is 12mm from the top of the rail to the base of the adapter. The maximum height is set by the internal screw, which can be adjustable. But the screw that I'm using is good enough to give me the height of 80mm from the top of the rails to the bottom of the adapter. My support clamps a diameter from 73mm to 78mm. I was told by Aaron that the Economy like the Extreme is 76mm.
