What you are referring to is the new "Full Frame" 1/2 relay. It allows full frame SLR lens to be used with no magnification factor. An 85mm is a 85mm. But you can't use 35mm motion picture lens because there would be massive vignetting. Unless removal of relay and use standard camera lens.
The SGblade combo with the GG.relay can give both frame sizes for 2/3 without the need to buy two relays... just by chenging the setup of the relay you can have the other configuration, so depending on the job you can configure your setup with just a 1K$ extra cost. Its comming also a 1/2 convertion kit that will allow the owners of the relay to reconfigure the relay for 1/2 cameras with again just a 1K$ extra cost. Additionally will be supported the Scarlet 2/3 when it will come out for the same amount.
So one relay many setups = future proof investment.
The Letus is f1.4 wide open and the SGBlade combo is f2.4(2.8?)
That's a big difference or not?
Have you seen the performance of 1.4 with the Letus relay? if its not stopped down to past 2.8 its not even close to SGblade/GG.relay... also a major role in light performance is being the ground glass... the RR3 is by far more efficient...
The starting aperture are exactly that "starting". I could put F1.8 on mine... the image would be similar to the Letus compact if its set to 1.8... totally defocused... not just soft... what is the point? just marketing? just to say that is F1.8?
Pro 35 wide open is just a bit soft, Letus compact to be compared to Pro35 it has to stop down past 2.8... so if you knew that Pro 35 is F2.8 wide open you will thing that the Letus is better?
Have you seen a single res chart anywhere with F stops for Letus relays?
Or should I put like Pro35 ND's insted of aperture numbers to hide the truth?
All I have done is public and posted on this forum res charts, images and footage so if you think is better just publish your chart with F stops.
My relays are as fast (or a bit faster) as Letus compact, a half to 2/3 of a stop slower from Letus Pro/ultimate and Pro 35 when compared with same lenses on S35 and SGblade with RR3.
With the same amount of money that you buy just a Letus compact relay you will be able to buy a bundle from Shoot35 with relay and SGblade thats about 3,3K$. If you consider the environment and how fast thinks are changing and what you can buy with 9K$ or with 14K$ instead of just an adapter... I thing our investments in this environment should be very wise. And that is the design philosophy behind my relays the best for the less possible money, for a market that changing fast, really fast...
How do you assume what f stop one will be shooting at. Everything is not shot at a f1.4. And the iris is not the only thing to effect the image.
So, if you're shooting at f4.0-5.6, what is the advantage of ff35 over Academy? Is it the increased field of view with wide angle lenses?
I cant answer yet... tomorrow the answer...
I will hold...![]()
