When using long lens (135mm) with Letus Economy adapter the ground glass pattern becomes visible. This is particularly apparent when the lens aperture is >=8 and while shooting the large areas of same color/luma (such as overcast sky). Constant (invariant) pattern appears on the entire frame - it looks like small patches (brighter and darker areas). When I switch the adapter off it becomes obvious that these patterns are caused by the ground glass - all the dark spots of the ground glass turn into dark areas when the glass shaking is switched on. I don't experience them with shorter lens. Has anyone experience this?
- Hubert
- Hubert
