Letterbox getting Stretched
gco
I figured this would an easy search topic but somehow I'm just not finding it.
I'm capturing 4:3 letterboxed footage. The capture window expands out to 16:9 and stretches the footage to fit when the capture starts.
Under Preferences/preview tab, changed the pixel aspect ratio to .9091(ntsc DV). Now the preview looks correct. Its 720x480 as I would expect.
The problem is that I am still getting stretched clips even though the capture window looks correct; i,e. if I go into my hard drive and pull up a clip outside of Vegas, it plays as stretched 16x9.
Project Properties are set to 720x480 ntsc dv 29.97/lower field first/.9091 ntsc dv.
Question is why are my 4:3 letterboxed clips being stretched out to 16:9 and how do I change this so that clips capture and display as letterboxed 4:3 ?
many thanks in advance,
g
ps--one thing the search function did do is convince me to ditch the letterboxing and use the tape instead.
I assume you're seeing this in Windows Media Player?
I've experienced this myself -- it's not a reflection of your footage, but apparently a quirk of either VidCap or WMP when they see black bars.
Yes, forgot to mention that it is WMP.
At least it sounds like I'm not missing something obvious here.
Thanks David!
