Lessons Learned, Part 88
ptalsky
Hey all,
Just came off of two days on a project where I got to use much of my new equipment. First, let me say it was a pleasure to meet in person Scott Koue (AKA Noiz2). He dropped by the set to check out my setup and watch me fumble a bit using the new equipment.
So, here's a basic brain dump (I just got home, so this may not be entirely coherent - I'll amend later as needed).
1. Not sure if someone here recommended them, but the Xantrax battery backup systems basically suck for cart work. The one I tried has a very loud fan, and for some reason started alarming after only a couple of hours of use. I'm going to hang on to it for power failures here at home, but that's about all it is worth.
2. I have a new love: Lectrosonics. My first two R400a/LM sets arrived and OMG, what a joy. They were shipped on Friday, so I had them Fedex'd directly to the location - a bit nervous trying them out for the first time on the set. I need not have worried. Select auto tune, get out the little Lectro screw driver, turn the nobs and away you go. They work beautifully, sound great (I was using B6's on both of them) and now I'm ready to order more. Be advised that these puppies took over a month to be delivered by Lectro, so know that before you need them.
3. Countryman is still my favorite company ever. They made me two adapters for my B6's to go G2-Lectro. This way I can still use my B6's and EMW's on the G2's for bag work, and still go with them on my Lectros. Very cool. Rosa at Countryman (their head techie, she's been there for 15 years or so...) originally told me she couldn't do locking female plugs for the G2 side - and when I go to pick them up, low and behold, locking G2 females. They did this in a day for me. :-)
4. Boom Recorder is a great tool. Most of the weekend I was running 6 mics - boom + 5 wireless. BR handled everything very well. I also tried writing the files out to two drives - the internal drive on the Mac and an external as a backup. I'm not sure if it was the double disk setup or the fact that overall I was recording 8 tracks, but there was a bit of a slow down in the writing of each take at the end of the take. I also have a workflow question I'm going to check with Take Vos on (and any other BR users, please chime in): Once you set your basic set, do you add or subtract tracks when they're unused, or just record blank tracks to keep the number of tracks the same all the time? In the past I'm usually just recording 4 tracks, so I've always just kept it at 4 no matter what. But, keeping 8 going all the time leads to lots of data - over 8GB for just one day.
5. I'm still running the HD-P2 as a backup, and it really isn't a big deal. I can Firewire the files off the chip and then just keep them with the rest of the days files. And, it gives me a bit of extra piece of mind. Here's a new tip for those using this setup - in the notes field in BR, I started each note with the corresponding file number from the Tascam, so I don't have to keep any special backup notes seperately. Of course, if the BR files completely fail, then we're screwed, but it seemed like a good idea at the time. Oh well.
6. I'm also using a new cart - the Rock N Roller with two shelf kits. I really like it - except that my Mac won't quite fit on the bottom shelf, so now I am having to stand to mix - but this turns out to be not that bad a thing. Once I get to work tomorrow I will post pics of the new cart all decked out.
7. Another trick for G2 users when your cart is away from the set - move the Rx's closer via XLR. Yesterday and today, I had them taped to the wall just outside the conference room we were shooting in (my cart was about 30' away). Made the reception much better on the G2's (of course the Lectros did not have any problems at all. :-)
8. I've said this before and will say it again, Hypafix tape, while expensive, is great for taping lavalieres under clothes. It is pourous, so you can put it right over the mic head, and sticks well, yet doesn't hurt the actors too much when it comes off (except for those with hairy chests). :-)
9. Another thing I've found that helps with wiring lavs under the clothes: Put it mid-chest (cleavage or between the pecs) and bring the wire directly under the pecs/breasts around to the back. This seems to solve wire rub problems (as opposed to mic head rubbing problems) with clothes. Especially if your talent has a larger stomach, where their stomach will force more rub.
10. Before my next project, I am getting those velcro strap/pouch combos that Trew is selling for mounting mic packs on talent. Today we had to fumble way too many times with wardrobe that was not designed to have a mic pack hidden inside it. One poor actress today had to stick the pack into her panties because there was no other way to secure it, other than to tape it to her thigh, and that would have taken too long. And, to make matters worse, she stood up at one point and down came her panties because of the weight of the mic pack. Oops. Made for a good laugh on the set. :-)
11. Another must for me moving forward is anti-bacterial wipes. The set was fairly hot (massively over-lit) and mic packs were coming out a bit sweaty. Eewww. Purell is also going on my cart from now on.
That's about it for now. I'll post more tomorrow when I'm not falling asleep.
Let me know if you have any questions.
Thanks!
(And thanks to Scott for your help yesterday! And for the coffee, I can't wait to roast some up!!!!)
Phil
Thanks for the equipment reviews. I just shot a 48-hour film followed by a wedding so I know how you feel.
Phil,
Was a pleasure. One thing that theatre folks do with wireless transmitters is stick them inside condoms , non lubricated please - bumps if you want. Especially in musicals where your micing folks who are dancing and such the sweat has been known to short out the transmitters. Sweat is a very good conductor and fairly corrosive. It's probably not such an issue in films because folks aren't on for an hour at a shot as they often are in theatre. We also used to have the wardrobe folks make up pouches with elastic belts to hold the transmitters.
Phil has a very nice and very portable system, I should have brought a camera... I liked the cart, the Tascam looked better than I thought (in terms of functionality - I knew how it "looked"), Boom Recorder was slick to see in use, I own it but have yet to use it for anything real. I did do a stress test though recording 32 tracks, double files (so 72 files) to a USB2 bus powered drive and didn't have any hiccups. I'm planning on using it for a 16 track recording where I will want backup, hence the test. It should be a dream with the eSATA drive I will be using.
I almost never use wireless (don't actually own any anymore) but the Lectors had me drooling. While Phil was busy standing by ;~) I went off and read the manuals, man ... He didn't actually have them setup while I was there (they had just arrived), I'm glad they lived up to the manual.
Now to find a battery operated espresso machine... Actually I need to talk to you about a gadget Sweet Maria's sells that works quite well in the field.
Cheers
In a pinch you can use 3" wide Ace bandages with velcro attachment to mount a G2 (or other wireless) to the waist, thigh, or lower leg... just run the bandage around several times, making sure it's tight enough to hold secure while not distracting the actors too much... it works almost perfectly to put a pack in the small of somebody's back also... (add some wide gaff-tape at the seam for insurance).
Ditto on the Countryman... just bought the HD-P2... and yeah... running XLRs to get the G2 receivers in as close as possible is highly recommended. For Countryman B6 on the ear of an actress, bend it around and hold it before you mount the lav... so that it pokes down just around the ear and out of the hair... then I use something like the medical tape you mention on the back of the ear to secure it... then have a loop before the lav runs down the back... and tape again at the top of the back... so that the loop can allow for some fudging of the mic. If it's out of the hair then you're golden... plus if you know the blocking of the scene you can cover another actor that ends up on that side.
Thanks for the post... and thanks for the use of the Comteks!
The whole "lessons learned" thing is making a nice collection of reality reports.
Here are the cart pics I promised...
Front view, annotated - Oh and left out of the picture is the third G2 Rx that was taped to the wall in the conference room to get it closer.
3/4 view
Phil
Okay, now that the fog is clearing (I actually got some sleep) I'm remembering more stuff:
1. With the Lectros, be sure to have all other Tx's turned on before hitting the auto-tune button. Otherwise you don't necessarily get a good clean tune. And, once you've tuned one Lectro, be sure to turn that one on before auto-tuning the other one. Also, be sure to allow a few minutes for this process. It takes a bit.
I'm sure more will be forthcoming. :-)
Phil
