Left to right adjustment with Letus Extreme
hennbot
Anyone have any advice for making left to right adjustments with the Extreme and HPX170. The GG image is pretty far to the left an I would like to center it up. Any ideas?
you can't. The offset doesn't adjust unless you have the ultimate. Regardless, you should zoom in far enough to get academy frame.
wow, good luck. Theoretically this should make one side slightly softer as your changing the optical path ever so slightly. But cool.
