LED Ring Light
That is an interestingly designed & machines ring light.
I agree with the rest that 3 or 4 or even 5 more rows of ring lights should be added. The more rings of light you add, the more it becomes an "area" light. Area lights are generally composed of many point lights arranged in straight rows & columns inside a rectangular or square perimeter (can also be circular). One advantage of area lights are that they cast very soft shadows. Good for portrait shots or shots of people's faces. There will be no hard-edged shadows as a result. Area lights are the best method to achieve soft & subtle shadows. If that is the aim. What bulbs did you use? Normal bulbs, or halogen bulbs & what are the wattage ratings of each bulb?
