Eric Coughlin
Looking for a 1x1 LED that's say around 10 lbs or less, at least bi-color but RGB would be even better. What's the recommendations now?
I guess I'm pretty familiar with what's out there but interested in opinions.
As for my experience, let's see here. I have a Luxli Timpani that randomly died; maybe I accidentally plugged another light's power supply into it and that caused the death, or it just randomly died. Apparently out of warranty and Luxli quoted $500 to repair it. Not cool. The light sells new for $800.
Then one of my Astras is in the repair shop (third time I've sent in an Astra for repair) for some broken plastic on the XLR connection, and they quoted me a high $350 to repair it. This is the 4x version that can be found on Ebay for, yeah, probably around the same price as the repair quote. Not cool.
I'm leaning toward not paying to repair either but then would need some replacements.
I've got two Practilite 802 panels which have worked pretty decently but the Anton Bauer mounts have never really worked right. They're not compatible with fitting my Anton Bauer batteries. I ordered a replacement for one of them and still the same issue.
Another of my Astras has been having some issues turning on so it's probably getting ready to die.
My Litepanels Gemini, the knob to increase or decrease the brightness is finicky and malfunctioning, as it skips all over the place when turning it so it takes extra time to eventually get to the desired brightness level. Otherwise it's been working okay and is typically my main key light.
So, Luxli crapped out, Litepanels crapped out, Practilite battery mount doesn't work. All of my panel lights have issues.
I'm considering the Creamsoure Micro. Five year warranty. Now that's what I'm talking about! Biggest downside seems to be that as far as I can tell you can't have both the power supply and battery mount mounted on the light at the same time, which makes switching up between the two cumbersome as I often switch between battery or AC power while running and gunning in the field.
There's the Litepanels Gemini 1x1, but I'm skeptical of Litepanels' reliability.
BBS has an expensive $3300 RGB 1x1 panel light which is probably nice and reliable but also appears to have the choice of battery or power supply like the Creamsource. The Rotolight Titan 1x1 is a comparably priced option to the BBS but weighs almost twice as much, so is a bit heavy for my needs for a light weight 1x1. I saw different specs for the wattage, from around 220w to 350w; if the latter this could be a smaller form factor replacement for a Gemini which is 325 watts. I always like smaller.
Then there are the Profoto form factor lights like the Aputure 300D and 600D. I'll probably get an Aputure 600D, but it doesn't really fulfill the need of a 1x1. Like, a light you can easily Hollywood with a battery, that is already somewhat soft without a big softbox like what a 300D would need. There also aren't much affordable RGB options in this form factor at the moment, as the Hive 575 and Arri Orbiter are rather pricey.
I think the Creamsource Micro takes the lead, currently. Also, their 2x1 the Creamsource Vortex at 650w for a light that is similar weight and size to a Litepanels Gemini, but twice the power, and with a five year warranty...these two could be a good combo.
