nyvz
I'm constantly on the lookout for new lighting technology that will change the way I work, and for the most part LED seems like it has a lot of potential, but almost all LED lights designed for film production seem to be pretty seriously underpowered or overpriced or both. For example there are the many <50W panels that are marketed saying they have 500W-1000W of incandescent output but really that is comparing to a light heavily diffused and wasted in a softbox, and these <50W LEDs at best have only the output of a 150W-300W fresnel at the same beam angle. They are useful when you want to run lights on battery or need daylight balance, but they usually lack in color rendering and some are still >$1k despite barely outshining a 300W fresnel while rendering much worse shadows...
Then there are a few bigger LEDs like the new ARRI's and Creamsource's which seem to put out about as much light as a 1K, but they are in the $3k-5k range...
One thing I've been looking at lately are RGB LED products such as the inexpensive ones used in LED ribbons which are pretty interesting because you can get 72W of SMD RGB LEDs that are small enough to mount anywhere on a ribbon for only about $20 for a 72w 5 meter kit with remote controller. These are cool in that I mounted them on a coroplast panel that weights nothing tape them anywhere and run on a cheap 12v li-ion battery for hours and can put out any color you want and controlled remotely. On the other hand their light output is quite underwhelming, partly because the "72W" strip only runs around 40W at the rated 12V, because it uses resistors to adjust voltage which just waste a fair percentage of the power, and have no lenses so they have none of the punch LEDs are known for with their commonly quite narrow lenses. These are pretty cool but are probably better suited for installations in sets, though I am tempted to try to build a big flexible blanket light from the 4 I bought
Those ribbons got me interested in RGB LEDs since I was surprised how good they could look on camera despite being very cheap LEDs. I expected narrow spectrum R G B leds being combined would render odd colors since clearly parts of the spectrum must be missing, but then they seemed quite good perhaps because cameras can only see R G and B through similar filters anyway. This made me wonder if there are cheap, bright, small LED fixtures out there that could compete with 400w-1.2k HMIs or more.
That leads me to what I really wanted this thread to be about, though, is that there seem to be lights marketed as DJ lights that are designed to replace PARs, that pack many bright RGB and RGBW (+white/daylight) or RGBA (+amber/tungsten) LEDs in one, inexpensive, DMX unit, and I've seen ones online that are anywhere from 3W to 720W. The largest ones I have seen that are easily available from american sellers at reasonable prices that are probably no bigger than a 300W fresnel are $250 18x10W units that pull about 180W and with photometrics that seem to show them competing tungsten fresnels of about 650w and should compete with ARRI's LED L7-C Fresnel lights at 1/10th the price since it pulls a similar amount of power for its LED emitter. Looks like there are some LED PARs that also have adjustable zoom (aka beam angle) though those might cost more. There are also units that use 24 10W LEDs and then panels that use as many as 72 10W RGBW LEDS that might really start to compete with HMIs.
Personally I wouldn't mind a non-focusable LED as long as it came in a very narrow beam angle, since it's much easier to diffuse a narrow spot light to spread the beam than it is to intensify and narrow the beam of a flood light.
Anyone have any experience with these or other relatively inexpensive LED lights that are worth looking into?
