Would like your opinions and suggestions. I am looking to update my lighting kit and debating between Led Panels or Fresnels. At the time being I can only afford one or the other. Need them primarily for interviews, for two person setups. The panels will give me more broad soft light and should be ideal but occasionally I run into setups where clients want to shoot with open windows in the back to capture the background and Fresnel would provide more punch. So far I have been using tungsten and led's only for backlight. I am looking for something with the following in mind:
1. Good color rendition.
2. High Output
3. Solid build.
4. Under 15lbs a fixer
5. Budget under $2000
Right now I am considering these two models:
Dracast LED1000 Silver Series Foldable Bi-Color LED Light
https://www.bhphotovideo.com/c/prod...rsf_1000b_silver_series_led1000_bi_color.html
Dracast LED1500 Bi-Color LED Fresnel with Wi-Fi
https://www.bhphotovideo.com/c/prod...drwf_fl_1500b_led1500_fresnel_with_wi_fi.html
2. High Output
3. Solid build.
