Norman99
Just finished a request from a fellow videographer in New York wanting 3 battery operated LED lights.
Before I send them off, I decided to share a few pictures of the units as they were in the final stages of having the rear battery plated installed.
The 4 units are identical with the 14.4 volt pro battery plate.
the unit draws 80 watts and puts out 7000 lumens or equivalent to approximately a 500 watt filament.
There is a selector switch for 3 of the most commonly used color temperatures 3200-4000-5500K
The dimmer goes from 0 to 100% without flicker or color change, LED driver is non-PWM type so there is no banding at high shutter speed camera rates
Enclosure is one piece aluminum , dimensions are 6 X 4 X 3 inches, weighs in at 36 ounces without battery
Provision for powering DC in from 12 to 24 volts, 4 pin XLR and 2 pin DC barrel, as well as choice of battery plates 14.4 V such as the Sony BPU seriesor equiv.
Diffusion panel is Bayer Makrolon XT in the neutral rendition, beam angle with diffuser is 120 degrees in all directions
Without diffuser the beam is 35 degree or interchangeable TIR optic choices of 10-20-35-40-60 degrees
All wiring is mil spec silicone 18 72 strand silver
Dimmer pot is mil spec Allen Bradley 250,000 turn
Finish is powder coat black
Twin mounting 1/4-20 female as well as illuminated led blue indicator power switch
Fan is PAPST ultra silent 18db that activates when temp sensor requires it
3 of these units fit in a carry-on with room to spare for batteries, chargers, and 3 small 5' tripods
