Hiro Nakamura
Hi guys,
I am a bit annoyed by noticeable noisy floor when I am using my wireless set.
So... I did fxxked around the wireless gain settings a bit, I was trying to make the noise ratio go lower and lower,
but in the end, the more I try, the more confused I got.
Currently, my UCR411 audio level set -21db, and my sMa which has 0 to 44 db as the range, I set it as I speak a bit lound with a countryman b3,
I got solid green light on -20 mark on the transmitter... So I set 10db on the sMa.
This is a normal setting that everyone is more or less using or you guys have different way on how to set the wireless.
I used to set the sMa as 0db, and UCR411 as 0db , it sounds the same with UCR411 -21db and sMa 10db regarding the noise floor.
Sorry for being so ignorance!
Thanks for your valuable inputs
Hiro
Hiro
