I'm looking to get a lav mic and would like to get your recommendations. Currently I have an Octava 012 and an AT4073a. I've read this link:
http://www.locationsound.com/proaudio/ls/tips/techtips8_4.html
I've also read Jay Rose's book. I'd like to get a mic to use as a plant mic that would cut well with the other mics. Also, I'd like for it to double as a clipped-on interview mic. This would be used on short features or doc interviews.
Size is not critical. If smaller size results in more self-noise and less durability, I'd rather go for a larger can that lasts longer and is quieter. This will be going into a Panasonic DVC80, with cables, not wireless. From what I've gathered, an omni is way more versatile than a harder-to-use cardioid.
I was ready to get a Tram TR50 (seems like a good all-around lav mic) until I read Fred Ginsburg's article:
http://www.equipmentemporium.com/Lavarticle.htm
which is about proximity versus transparent mics. It's a feature I haven't really heard discussed before. It sounds like an ECM44B or TR50 would work well as a general purpose lav, working okay for both transparent and proximity uses. He also implies that having two mics would be even better, like an ECM55B for pure proximity and an ECM77B or AT-830R for pure transparency. (But if the ECM55B is the fat "newscaster/infomercial sound," then I definitely dont want that.)
So basically, I'd like to just buy one mic, unless this is just too much to ask for with one mic, in which case I'll reluctantly get two (kinda like the Octava and 4073a dilemma). The Sanken COS-11 seems kinda pricey, but I'd consider it if it's the do-all mic.
So the mics I'm considering are the COS-11, EMW, B3, B6, 44B, 55B, 77B, AT899, and TR50. Your experience and opinions on this are appreciated. My questions:
Where do the Countryman mics fit into this spectrum of transparent/proximity?
For applications where this is a plant mic (like a wide shot two-shot), does larger element always equal lower noise?
Are the super-sensitive mics like the ECM77B and COS-11 just a total pain to work with for clipped-on interviews? Or are they workable with a bit of skill?
Thanks in advance.
Thanks in advance.
