Alright.
I am going to be using a laptop with the HVX in myriad ways and as I scheme and scheme, I wonder what other people are thinking of.
1a) I will probably be using 4G P2 to start off and I can plug into the Laptop
1b) or I will be streaming into my Apple Powerbook for longer uninterrupted recording times.
These are in controlled environments,
However, I will be using the HVX under many conditions - I want longer recording times and must be prepared to be the one man band
so here are some configurations I am toying around with:
2) I like Barry G's USB2 HD solution. Sound like the best and cheapest. (But we dont know of reliability yet and it takes a few minutes.)
3a) Capturing it directly into a laptop if it is small and easily strapped onto your body. ( I tried putting my 17" PB into a shoulder sack and Capturing with my Sony and it worked , but was a bit awkward. But I'm sure with more practice, and a smaller Laptop, it would be fine for on the go)
3b) However, I also do some light steadicam work and I imagine fixing a small laptop to my Vest So I can Use it as a monitor as well and directly control Log & Capture. This seems like a very nice solution.
In Fact, without the steadicam, for handheld work (or not) - I imagine using a vest with a small laptop attatched to my chest or abdomin keyboad flush against me, screen at 45 or 90 degrees as a monitor
(having a larger Hard Drive in my backpack is option too)
...Even if I am only using P2 Cards to record, this makes it easy to transfer data through the Card Bus on the fly as I shoot !
4) PROBLEM: I also will be attaching a 35mm adaptor to the HVX and it will not be one that FLIPS the image. So I would need to FLIP the monitor of the Laptop somehow...Not easily done with an Apple.
Okay so maybe I give up the laptop as moniitor solution ...BUT it is so close!
The monitor Flip Function is the biggest deal to this being the perfect solution to the Myraid Ways I will be using the camera - wether in studio or run & gun
Do I go to PC? and use a Tablet that I can FLIP?
Maybe I just HACK an Apple 12" PB...
I love the Laptop as a recording/storage/ and monitor for the HVX.
There is something So Elegant about it. HVX & Laptop and you have everything you need (not to mention editing & DVD back up)
It is very close to the Perfect solution.. so close & yet so far (like the Arrival of the HVX itself)
How are others Preparing?
