Lag Odyssey 7Q
Fader8
Hi everybody,
I have the feeling that there is quite some lag over the sdi on my Odyssey. Is that normal? Can be a bit annoying for fast moving stuff..
Thanks for the feedback.
Cheers
I think it's the FS700 unfortunately... It's very annoying. I do a lot of music videos and seeing someone singing out of sync drives me nuts... It's even worse via HDMI... Which is why I wonder how people can use the FS700 with viewfinders...
Make sure to have the latest firmware update loaded - 2016.10. In HD ProRes mode there had been some additional lag introduced when we added Dual-HD monitoring last year. This has now been adjusted so that if there is no second HD signal present the added lag is eliminated. We were effectively double-cycling the signal processing to accommodate multiple HS signal paths.
