Keying with ultra-key
tazza
I am about to shoot an interview using a chromakey green background. My client might want to use their (green)company logo to be keyed in as the background.
My question is:
If i pull the key - green channel- does this keep me from replacing the background with anything green?
My question is:
The 'key' operates on the layer that has the greenscreen. Hence, any other layer is not affected by the keying. However, in the greenscreen layer, if a person has something 'green', that may be a problem, and may require a garbage matte to 'cover' the green areas of any clothing. However, if the person moves, you may have to do a traveling matte to compensate.
I've only used the AE keying, Keylight, and there were a number of controls which allowed one to try to get the best key out of the screen.
My skills are limited to using he Ultra Key plug-in in Premiere. So if I'm understanding correctly each layer of video on the time line has it own RGB channels - so if I have to lay in a green colored logo, and it obviously needs to live in a different layer of video, I'm good to go.
Thanks for the info.
My assumption is that the Ultra-Key plug-in you are using in PP, works on individual clips, 'layers' is sort of perhaps the wrong term to use in PP, more of a AE term... but in any case, the plugin should only work on the clip you apply the plugin to, and not others in the sequence.
Short answer: This will not be a problem.
Longer answer: The Ultra plug in only affects the clip that you assign the effect to. Therefore, if your green logo is a separate clip on the timeline (a jpg, png, or psd) the ultra key plugin will have no affect on this clip.
