dakotapod
Whipped up a quick template in Photoshop for Premiere Pro shortcut keys. You can laser print it on 8 1/2 x 11 label stock at Kinko's or similar for a buck or two. You can fit two per page so if they get a little worn you have a back up. I wouldn't recommend an inkjet, wouldn't last very long.
There is a slight bleed and trim marks to help you cut to size.
Throw them on a $10 black keyboard and you're good to go. If it is of any use to you be my guest!
I haven't printed off the jpeg version so if it's fuzzy let me know and I will toss up a larger file.
Cheers 8)
Dakota
http://www.nucleus.com/~toddp/Prem-Pro-Keyboard S-Cuts.jpg
Cheers 8)
Dakota
