Peckhammer
I own a Kessler Crane. It works really well, and my only complaints about it stem from my particular idiosyncrasies. I use a crane or jib as way to achieve smooth movement, mostly. I rarely need a high shot. I find the Kessler crane a little awkward at times, and some of my shots are a bit wobbly because my tripod head and sticks are a bit under-rated for the weight. The sticks are flexing, and I am too frugal for my own good.
The Kessler Crane mounts on a tripod head and tripod, is typically operated from behind, and has a lever for tilting the camera up or down. I prefer to operate the crane from the middle so that I have more control by directly interacting with the tripod head.
The Seven Jib Compact attaches to a tripod without needing to be attached directly to a tripod head. The head is located at the front of the jib, and the camera mounts to it there. It appears that you operate from the front, and camera control is very direct. The camera can be under-slung with a bracket. For my kind of shooting, this has some appeal.
The Seven Jib requires sticks that have a 100mm bowl, which I do not have. So in addition to the $1200 Jib, I'd need better sticks. Money is an object here, and since I already have a Kessler Crane, it may be cheaper to just buy a Kessler K-Pod system and Hercules head, and then use my 501 HDV head on the camera mounting platform, giving me similar control to that of the Seven Jib. That said, the Seven Jib looks very easy to operate, and appears to have a better under-slung mounting system.
Thoughts? Advice? Experiences? Recommendations?
