Hey all, i'm thinking of getting a jib to up our production value.
I often shoot alone, on occasion with an assistant. I shoot with an FS700, and will most often use the 10-18mm E Mount lens. It's a very light lens, so i should definitely be well under 10lbs. Looking for a jib that's relatively easy to set up and operate. Also affordable.
The KC Lite 8.0 from Kessler Crane looks great to me.
http://www.kesslercrane.com/product-p/100041.htm
I like that you can tilt the actual camera by tilting your tripod head, not sure how smooth that method works however.
Before pulling the trigger on it, i thought i'd see if anyone has any impressions to share after using that particular jib.
Is it steady? Strong amount of wobble back and forth? I haven't been able to find many reviews on it.
Hoping to keep it around $500 at most, btw.
