JVC TM910 Sufficient for focusing with RedRock M2
TimothyJinx
Is the JVC TM910SU monitor sufficient for pulling focus with the RedRock M2?
If not, what would you fellas suggest?
I used it to pull for my last project after my VGA converter blew up half way through the shoot. I used the JVC and the HVX focus assist to double check my marks and the results were just as good as the ones I was getting off the HD monitor, though it took me a bit longer to check each setup and be sure I was good to go.
With only 300 lines of resolution I wouldn't recommend pulling focus JUST with that monitor, but if you also use the EVF detail and Focus Assist in addition you could get by.
You can be sure of this: if it looks out of focus on that monitor, it's definitely out of focus.
EDIT: I just realized this is the DVX section, so assuming you're shooting SD then I'd be 100% comfortable using that monitor for focus.
