JVC GYHD110 with SGPro too high?
cordvision
I tried to use my SGPro with a GYHD110. The lens was about 1 inch to high to mount to the SGPro. Could it be that the GYHD110 doesn't conform to the standard which is I think 85mm from the rails to the center of the lens?
I use the Zacuto Rails. The GYHD110 lens seems to be way too high. I can't lower the baseplate that much. The SGPro conforms to the standard high, right? (Which would mean it's a problem of the Cam...).
PS: Wayne: I completely forgot to thank you for the fast return of the Adapter, it works now perfectly and I get great results. It's really a nice adapter!
Hi,
Yes, the SGpro is standard 85mm from rods to lens centre. All cams have different height from their base up to their lens which is why you need an adjustable rods support.
No probs on the turn around, we are glad you're happy with it :)
