For shooting interior interviews, I noticed Home Depot has a 2-head halogen worklight, adjustable, with 3-way dimmer for $70. Don't laugh, but I have to ask! Small budget.
Arcburn, first - I really liked the movie. The eating of toes may be a first in American cinema!
Second, the lighting is impressive. Maybe a trained eye would know you used worklights, but I couldn't tell.
I also would like barn doors to stop the spread of light. some soft boxes so the light was more diffused and softer. And the ablility to use colored gels.
I figured I could work with the work lights for a bit and figure out lighting principals while i save up for the others.
But you can still get cool lighting with the work lights.
I saw a suggestion somewhere that you could soften the worklights with...fabric softener sheets. They're white, translucent, and made to take high heat. I'd definitely try that...worst case, use 'em for laundry!
I bet someone has figured out a way to improvise barn doors. Maybe you could clamp on some small aluminum panels that bend easily and hold their shape.
Yeah, the biggest problem with worklights is controlling the light. You could snoot them down with several layers aluminum foil. Quite maleable compared to barn doors but not as precise. (Black wrap (Rosco) is just thick aluminum foil with a black coating but not as cheap as a roll of Reynolds Wrap)
The biggest problem worklights have is that there's such a thing as the Britek 250. For $76 you get a light that's focusable, mountable on any standard stand, can take scrims, and comes with excellent barn doors that even have gel clips on 'em. The Briteks are so much better than worklights that you'd probably be far better off to just save up a little and get some of them instead of trying to improvise and work around the limitations of a worklight, which was never designed for cinematography purposes.
Barry,
That's very helpful, as the best Home Depot worklight is $70. Would 3 of those Briteks work for an interior, seated interview in someone's home?
Hmmm, looking at that page it looks like they've even added some newer lower-cost options, with 200w lights with doors and focus control starting as low as $53 (after DVXUSER discount)!
