Just got an HV20 - How do I edit in Premiere?
c.g._eads
So I've entered the realm of HD editing. I'm terrified.
I have Premiere 1.5.
What I believe I need to do is upgrade to Premiere 2.0 to edit in HD, right?
In addition to that, is there anything else that's different in the editing workflow now that I'm editing in HD?
You have to strip out the pull-down frames using another program like After Effect. Premiere won't do it. If you're not willing to do that then you don't need 2.0. Just download the 1.5.1 update from the Adobe site and use the Sony HDV 60i preset.
oh man, that sounds difficult. I do have after effects. How exactly do I strip down the pull-down frames? I guess I would need fairly specific instructions. the correct process to get it into after effects, the way to strip the pull-down, and then most importantly, how to get it out of after effects with a minimum amount of quality loss.
bring the clip in to AE, then in the project window right click the clip and choose "interpret footage". A panel will pop up with all the framerate options including remove (or add) pulldown.
well, premiere pro 2.0 has a 24p option for new projects. not sure what the difference is but you might wanna try it.
