ok.
i'm still pretty much exhausted and i'll post something more lengthy after i sleep for a few days but i had to get this one thing out there for some feedback...
setup - sd 442, sd 744t, pair of oktava mk-012's, sennheiser 416
problem - actors levels
in between takes the actors would be conversing with each other and the meters on the 442 were nice solid -4 to 0's
and this was a fairly low level of conversation, they always forget the mic is there and they have fairly intimate subject matter etc.
but when the camera rolls their vocal level drops way off the meter
to the point where the meter isn't even always lighting up at all!
real problem - how do you explain to the director and dp and actor that the problem isn't in the mic or the mixer or the idiot sitting at the mixer but that the actors just need to project a little more?
the director see's it as though i'm asking the actors to "scream or shout" but i am merely asking them to speak at or near the levels they were at when they were just talking to each other between takes.
a small part of the dialog was supposed to be at a lower level and the actors were saying those lines at a true whisper.
to the point where people standing 6-8 ft. away couldn't make out what they were saying.
is this something that i am screwing up because i don't have a huge amount of experience?
or is it a matter of the actors just needing to project and to do a "stage whisper" when it is called for?
there were 2 or 3 very experienced actors in the cast and they were great, they could do a "whisper" and still hit good solid numbers on the mixer.
i could have the boom 3 or 4 ft away and still get great levels on them.
but with the other "actors" even in a tight shot where the mic on the boom could get as close as 6 inches from their mouth the levels were barely even hitting anything on the mixer. maybe a -14 at the most.
the only way i could get decent levels was to turn up the channel gain or the master gain until the background noise/noise floor was rididiculously loud and almost comical.
of course the dp insisted that i didn't know what i was doing and suggested that i had the mixer set for the wrong input type!
i had the same results with both the oktava mk-012's and the senn 416
matthew
matthew
