Hey all. A fine wealth of info you guys have here. I have a few questions, as I don't have a whole lot of time to search the site to find the answers.
The first is the topic of consumer cams for capture and playback. I've read that they work, and that's great. That's what I wanted to hear. Now, do any of you use one to capture with Xpress Pro/ Mojo? Are there any special tweaks you have to do to get it to work, whether capturing 24p or advanced? It's a concern because I have 4.5.1 and the only consumer cams I could find in the deck config. page were the Elura (doesn't specify which) and the zr10 (long gone as far as I know). Avid's site for compatible dv devices doesn't turn up any cheap alternatives that I've found either. And if you do have this set up, which little cam do you have? I need one preferably with an external mike hookup for filming read -throughs and auditions and also has dig/anal pass through. Suggestions, model numbers?
Question two:
Color corrected bulbs. Needed if you have color correction capabilities in your software? Or will white balancing solve the problem. Yes, I'm going for Home Depot specials. Oh, and by the way, if you need reflector clamp lights rated for 250 watts, the only place I can find them locally is Walmart for 7.50 a pop. Other wise, you have to go to B&H where they are 12 to 18 bucks. And what about using Lutron 600 watt Skylark dimmers with these lights?
Question three:
Gen Jer Dan, those barndoors on your site, Awesome. I checked the HD specials and saw that the bottome faceplate
hinges were a little to close to the front. Did you have a special trick for mounting the bottom hinge? Maybe they've changed the design a little huh..? Let me know.
And...
Question four:
For Barry Green, I want your book and DVD, but I'm interested in overnight shipping and paying with either credit card or money order. Can you give me and address, phone #, or email.
I'd appreciate it.
Pardon me if all this has been discussed ad nauseum. Your answers would be much appreciated by a fellow DVX user
guys.
Thanks, V
Question two:
Question three:
And...
Question four:
I'd appreciate it.
guys.
Thanks, V
