Jumping from 16x9 to 4x3 after i export as DV AVI
filmsg
It's like a random pulsing. Most frames are 16x9 but after a few it inserts a 4x3 frame. I know others have had this issue. Anyone find a solution?
I need to export 24 16x9 frames at their highest resolution for editing with another program. How do I do this?
Re: Jumping from 16x9 to 4x3 after i export as DV
Filmsg, export you avis as uncompressed. And where it says millions colors, change that to millions +. Also uncheck the recompressed box. Hope that helps.
I had this problem once. 16:9 then suddenly 4:3 - reason was it was doing the 4x3 when I applied transitions only as the pixel aspect ratio in the video settings was set wrongly/ It was set to 1 x 1 pixel and should have been !6:9 Widescreen. You must change this. Email back if this helps and you need more detailed info and I will take you through step by step...
