Issues with First MultiClip Edit
andrew00
Hey,
So I was trying to do my first multi clip edit this weekend and I found it quite difficult.
Back when I used to use Vegas, multi clip editing was easy - I'd just line up all the clips on the timeline, move them around till they're all in sync and click to create the multiclip video. This would create a video, in sync, which would begin when the first file started and end when the last ended. Then each clip would be easily editable and cutting done by pressing the number of the clip.
After trying my first FCP edit, I found a lot of problems with the edit:
1 - Syncing. Ok I know I'm coming from Vegas, but I found no easy way to sync the files. These were live music filmed files, where there wasn't a desk/truck sync'd time code - i.e. there was a bunch of guys filming who hit record when each band came out but not at the same time.
I found that it wouldn't let me sync them the same way as in Vegas by moving the clips to the timeline and moving them about till they're in line. Instead I could only create the multi clip by the files in the Browser.
Since these weren't in sync in the first place I had to go off the master clip and create a sub clip by using the audio wave and trying to set the out at the same point. Then I created the multi clip sync'd to these outs.
Phew, what a massive headache that was. Surely there's a better way than this as I intend to do many a multi clip edit for live music and it'd suck if I had to go back to Vegas because FCP is such a head ache.
2 - Editing keys. I found the editing also difficult because the key bindings kept messing up. I bound the cutting to CTRL + the numerical keys, where CTRL+1 would edit to Angle 1 etc. I think I had 7 or so angles.
Yet, I'd do seemingly anything and the keys would reset or wouldn't work properly, and I'd have to re-bind therm again and again.
Can anyone suggest what's the deal here, am I being dumb or is this just a 'feature' that makes it ten times harder to edit? I'm esp talking about the first point here.
Cheers!,
Andy
Easier Lining Up
Easier Lining Up
Andy,
I film live events (marching band competitions & dance recitals) where multiple camera operators are starting at different times. Here is what I do.
1) drag the clips for each band onto your timeline.
2) Add a marker (m) at your first obvious audio cue on each clip
3) If you click on the marker and drag, you can easily lineup the clips based on that audio cue.
4) Cut (Control-v) to make all of the clips start at the same time. In other words who ever pressed record last, go to that point and cut all of the other clips.
5) make a new bin (command-b) and drag these clips into it then control-click and create multi-clip sequence.
6) Drag multi-clip back to your timeline.
As far as FCP not remembering your keyboard layout, make sure you are saving it under Tolls>Keyboard Layout>Save layout. This way you can bring up your customized layout.
Hope this helps,
Jonathan Schwartz
CA Video Productions
