is this normal
Moseph
since the only type of displays that can show things interlaced is the CRT and LCDs can't properly show video interlaced, is it normal for videos to show up on a LCD a bit blurred at the full size of 720 by 480 when deinterlaced?
Depends what deinterlacer algorithm you use. If simple "blending fields" then you'll lose up to 50% of your vertical resolution and frames with motion are blurred. Using smart deinterlacer (or adaptive) makes things far better.
Good source to learn all about deinterlacing: http://www.100fps.com/
