footage that i did a time remap with, sorry for not stating that in the first place.
basically what happens is when I import the clip, its interlaced, but when i render it, it comes out deinterlaced.
When you render, make sure you check that you're rendering lower field first, assuming it's DV footage. I think if you select Best settings, it defaults to no fields, or progressive. In the render Queue, under render settings, select custom, then make your adjustments.
-Kevin
