Mommaerts
Hi everyone,
I just received a dv tape to transfer to my editing sweet. I don't know for sure what the format is and would like to make sure i'm importing it correctly.
Here's what i know:
1-footage was taken at 24pa
2-it was edited in vegas and i can only assume 23.98 if it was imported correctly
3-then it was outputed back to dv tape at 24pa and handed to me.
I beleive this was one of the first projects done by this editor and I'm not sure if they accidently exported it as 30 interlaced or at 24p or maybe didn't have the pulldown set enabled or something.
After capturing a different tape that i shot as a test using the advance pulldown removal setting in FCP i get clear images on each frame, it also appears on my browser as 23.98. Now when i capture this tape that was given to me i see a blurry frame every 5 frames, also it appears in my timeline as 29.97 even though the capture setting was the same for both tapes.
So the question came about, is there a trick to making sure that i'm importing the footage correctly? What if it was done at 24p then export to dv tape at 30i or maybe they didn't use the pulldown properly.
Is there anything i can do to ensure the integrety of my capture? should i be using a 29.97 timeline and give up on the 23.98? (note: i still see a blurry frame every 5 frames but once in a while it's every 4 then back to 5)
If someone could shed some light or put me at ease before i start this long process of colour grading and matting for 16:9 that would be very helpful.
Thanks to all who reply, you guys kick ass!
(M)
Here's what i know:
(M)
