Hello,
I've been trying to find a solution to a problem I have for a long time, and not come to any conclusion. In 2007 I had an HDV camera, and with that made some decent recordings using the Rode NTG-2 that I got at the time. More recently I got rid of the HDV rig, and moved to a vDSLR, and from what I read, ended up purchasing a Zoom H4n to record audio with. This setup however presented some harsh audio issues, as it does a fine job with its internal mics, but I have got very high noise ratios using my NTG-2 and an SM-58. I have tried using the Phantom, the internal battery on the NTG-2, internal pads and compressors and preamps, and even one suggestion to use an XLR to 1/4" jack cable, none of which have given me reasonable recordings.
I have, thus, considered getting a preamp, or an external phantom unit, but don't fancy the expense and need for yet another battery operated device to add to the collection. and weight to carry about.
According to some research that I made, the issue between the NTG-2 and the H4n is to do with the output/input impedence, which is 250 Ohm on the NTG-2 (300 Ohm for the SM-58) and accordingly 1 kOhm (balanced) input impedence on the H4n. This, it appears, is an incurable issue.
Or am I wrong? can this be cured? My idiotic logic would assume that the lower impedence of the mic would be providing too high a signal for the input, and thus peak. But this is not the case, and I have not read up on that technical side of things in a long time.
So I am wondering whether I should sell my H4n and replace it with a Tascam DR-100 which, I hear, is a slightly better unit than the Zoom. However, the Tascam website does not even hint what its XLR input impedence is.
So the question remains whether it would be worth my selling the H4n, and probably then having to invest an additional £130 to get the DR-100, or would I be better off getting a different shotgun mic, or a preamp with that additional investment?
Any help will be greatly appreciated, and when I find a conclusion, and test it, I shall post a decent blog to try and provide an answer to others like me.
Thanks,
Tobias
Thanks,
Tobias
