combatentropy
I read an article a few years ago and it had a good example of why scenics look so good when shot in anamorphic, using 2x anamorphic as the example. It was something to the effect of shooting normal spherical you may shoot with a 25mm to be able to get the shot you want, but in 2x anamorphic you would shoot with a 50mm. So the vertical FoV is that of the 50mm, but horizontally it's the same as the 25mm so it's still a wide shot, but everything feels closer because you're shooting with a longer focal length lens.
I believe this particular aspect would be precisely the same if you cropped spherical to 2.40:1. I feel bad smashing people's bubbles, but which would you rather have?
I am 75% inclined to denounce anamorphic as bikeshedding, but I am 25% inclined to say, hey, enjoy your little joys. Here are legitimate distinctions of anamorphic:
- oval bokeh
- horizontal lens flare
- barrel distortion (I thought it was a bug, but now I hear it's a feature)
- when desqueezed, the optical size of anamorphic 35mm happened to be almost precisely the same as full-frame 35 (https://www.combatentropy.com/frames). So you get the same depth of field, for better or worse.
