Is it deinterlaced or not?
patrickbaldwin
I have footage from my first shoot using a Blackmagic Video assist recording from a Nikon D4. It outputs 1080i at 50fps. When I checked this in FCPX it said that it was 25fps so I just carried on editing. I uploaded to vimeo and it said the video was interlaced. It looked just fine to me but it is a talking head interview so there isn't much movement that might display interlacing artefacts.
Anyway, I did some googling and then went back into FCPX and clicked the de interlace box and it changed to 1080p but its saying its 50p. When I reuploaded to Vimeo it still says its interlaced?
I'm so new to this I'm completely baffled. Do I even need to care? The video looks fine and I cannot see any difference between a deinterlaced version and a supposedly progressive version.
As I will be using this combination of camera and recorder a lot is there anything that I should be doing in FCPX when I first import this footage to change it to 25p? The footage is Prores 422 by the way.
I dumped the Video Assist after a couple days, so I can't check but in theory... If your footage going in to the VA is 25P and is then recorded as 50i, it should still look exactly like 25P even though it's tagged as 50i. At this point the interlace won't show any movement in the fields because their isn't any. Each set of fields is just half of the same 25p frame rather than a true 50i field followed by the next 50i field. You shouldn't have to deinterlace in this case, but just change the flags that tell Vimeo what kind of footage it is. I think you should be able to do this simply by copy pasting your edit into a 25p timeline.
If it really is 50i from the moment it was shot, then yeah you do have interlaced footage even if the talking head content doesn't show it much when paused. In that case you can deinterlace it, but keep in mind that when you do that you'll lose resolution.
Another thing to keep in mind is that the interlace won't show in your viewer unless that window is at exactly 100%. Any scaling can hide the interlacing.
Thanks for the replies. I went back to the original timeline in FCPX and checked the deinterlace box but then also found progressive in the field dominance override drop down menu. The footage is now flagged as 1080p @ 25fps. It did render it so something has changed! It doesn't appear to have reduced the resolution as it looks exactly the same to me viewing it 100%. It's something I need to check earlier in the workflow I guess. I'm still a little baffled as to whether the camera is actually outputting true interlaced or if its just some kind of "wrapper".
Many thanks again.
A very belated thank you Andrius for your reply. I have only just read it but it's still a great help in clearing this up.
Thank you again.
