commercialguy
Got this from the Fox Channel as the requirements to broadcast on their channel. It says 59.94fps at 720p. Most cameras shoot at 1920x1080p at 24fps, 29.97fps, and 30fps. So what should you shoot at and convert to?
HD Commercial File Specifications:
SD Commercial File Specifications:
- The file must be black to black, no slates
- The file should be created as a movie file (.mov extension)
- PREFERRED CODECS
- The file should be formatted for 720p.
- The frame rate should be 59.94fps.
- The audio should be Two (2) channels 16 bit uncompressed at 48Khz.
- The File MUST NOT be marked as a read-only
- Video Bit Rate: 30 to 50meg.
- The file should be formatted for 480p.
- The frame rate should be 29.97fps.
- Video Bit Rate: 12 meg.
