Ed Kishel
I am interested in purchasing the intensity card but have 2 tech questions first. I know the card captures full HD at 4:2:2 when the camera is hooked up live to the card but since I will be going to HDV tape first:
What’s the advantage to the intensity card over firewire card if you are capturing from pre-recorded HDV tape? If HDV tape is 1440 by 1080: is the intensity card just stretching it out to turn HDV into full HD (1920 x 1080)?
Or is the camera stretching the HDV tape source up to 1920 x 1080 for HDMI out?
And is this the same process for the color space, just adding info (either camera or card) to get 4:2:0 to 4:2:2?
After speaking with Blackmagic design- their salesperson stated that as long as you are using the HDMI out and not the firewire you are getting the full uncompressed 1920 x 1080 4:2:2 even if you are playing off tape. I understand how this works live because you are removing miniDV tape from the equation. But I thought once its on tape, its stuck in HDV specs.
Thanks!
Ed
Thanks!
Ed
