I'm looking for a quick and easy way to do an iris effect using Premiere Pro (1.5). Not the iris wipe transition, but the old silent movie look (vignetting?). So, there would basically be a feathered circle around the edge of the shot with maybe a little flicker. Any suggestions?
Easiest way would be to create an animation of a flicker using After Effects, save it with an alpha channel, or use it in Premiere via blending modes. I don't know that you can have anything like Wiggle as an expression, or even if you can use expressions in Premiere.
In AE, you can either use a vignette created in Photoshop and use the wiggler on it's opacity, or you can create a black solid, create a circular mask, set up the feather on the mask, and use the wiggler on the mask's opacity, or on the solid's opacity.
