Thats what I was thinking also.
Has anyone figured out a decent mic connection to get the iPOD up to par for external recording? Seems silly such a solid unit with so much HD space and it lacks in this department.
The mini jack on the Griffin iTalk is dual functional and can accept either an external mic or a headphone. The iPod only records in mono WAV files and at an 8mhz sample rate, which certainly limits its use for pro audio applications. I've used it to tape lectures and seminars, and for that it works fairly well.
I certainly wouldn't use it for audio; the current capabilities are far below what I'd use for sound work.
Dunno how it does as a portable hard drive, however; probably depends on your set up (i.e., using a laptop for recording and dumping that to the iPod, etc.)
As a portable hard drive it works very well. The data stream is not fast enough to capture or playback hi res video, but file transfer is very quick via the firewire. In fact, during the making of the Lord of the Rings, the digital dailies were delivered to Peter Jackson on an iPod. Check out this link:
I would not recommend the iPod for this purpose. It's a cool storage device, but not any good as a recording device. You should look into getting a Sound Devices 722 when they come out in September.
[quote author=Michael_W link=board=audio;num=1090214167;start=0#5 date=07/20/04 at 15:07:58]As a portable hard drive it works very well. The data stream is not fast enough to capture or playback hi res video, but file transfer is very quick via the firewire. In fact, during the making of the Lord of the Rings, the digital dailies were delivered to Peter Jackson on an iPod. Check out this link:
I got an iPod but I didn't know you could do that! So based on that Hollywoodreporter article you can store quicktime video files on the ipod? Hmmmmm....
You can store any type of files, but it's only storage. It's basically a fancy, expensive hard drive, that's all. To be honest with you, I don't think they're worth it. I'll buy one when they have a 5 inch color display so I can show quicktime movies on it to potential clients. I've never seen the need to have 2000 songs in one place at one time. You'll never listen to that many songs, especially in one sitting.
If all you need is storage, then just get a portable hard drive, like LaCie's pocket drives. They are cheaper, and more rugged.
I love my iPod--someone must have implanted a chip in me while I slept ;D. Having your entire music collection available anytime, anywhere is a revelation. At this point I view the CD with as much enthusiasm as a wax cylinder. They're bulky, they get borrowed and never returned, lost, they're not with you when you want them.
CD's couldn't be any less bulky. I don't let people borrow them, and they are always where I want' them. In my car (which has a CD player built in, not an MP3 player) or apartment. I don't need to have them with me at work, because I can't listen to music then. I don't need to listen to music while at the mall.
I just never saw the need to have 2000 songs in one place. I'm never going to listen to that many songs. I like to have smaller playlists of 10 or 12 songs, which is perfect for a CD. It's easier to deal with.
Oh, and MP3's sound bad. I have maybe one or two that sound good.
The only reason I could think of that I would want an iPod is for on set playback. I know a couple of production sound mixers that have 500 gigs of MP3's. They pretty much have anything you are looking for, and when the director or producer ask for a song for whatever reason, they have it.
does anyone know if apple plans on upping the specs on the ipod's recording capabilities (would this be a software or hardware issue)? if it did, it seems like the ipod would be fantastic for recording audio.
The PMD670 is a good machine for a fair price. The folks that I know that have them really like them. I would stay away from minidisc. I've never really liked anything I've recorded on them.
[quote author=Boomerang link=board=audio;num=1090214167;start=0#13 date=07/28/04 at 20:10:35]Marantz PMD-670 Professional Compact Flash Stereo Portable Recorder (?)
....I used a minidisc recently to record off a mixer from a band and was very unhappy.
[/quote]
The PMD-670 looks like a good portable recorder to me, since it can do uncompressed WAV files, and has XLR inputs and supports phantom power for mics. Note that the SNR spec on this unit (86 dB line, 65 dB mic) are OK, but not as good as you might expect for pro gear.
I use a HHB MDP-500 which is a "pro" minidisc set that looks physically rather like the Marantz you're looking at (XLR inputs etc.) If the Marantz had been available two years ago I'd probably have bought it instead (even now the HHB is still over $1k). I am well aware of the theoretical loss with ATRAC (MD compression) but I have never been able to hear an audible difference between my MD and uncompressed recordings. Note there are different types; HHB uses ATRAC 4.5 which is the best quality one.
Compression is only part of the story, there is a lot of harm that can happen in the analog input stages if you run hot levels into consumer gear (significant distortion, but short of hard clipping). My point is if you were "very unhappy" with the MD recording, my guess is there is some other problem in the recording chain besides just that it's in MD format at the end, so you should find out what it was; simply changing the record format may not fix it.
