Mitch Gross
I prefer to have a hard light with a more directional beam angle vs a hard light without any directionality. I am looking forward to my focal spot and fresnel shipping when they become available.
What I feel is currently missing from RGB LED systems is something similar to a Joker/Bug. A system that can act as both a hard source by adding a reflector while also having the option to have a broad beam spread for a softbox. The flat, disk shape of the COB and heat transfer requirements may make this entirely impossible. Also, a panel light is just far more efficient as a soft source even with a softbox attached. I just appreciate how small these COB fixtures are and wish I could replace my mixture of heavy panels and HMI's with a bunch of COB lights, reflectors, and softboxes.
Both the focal spot and the fresnel should be bak in stock very soon (days). We had a huge demand and sold out a little faster than expected, but our supply chain is solid and we'll have full inventory on everything very quickly.
So are you asking for a basic single element lens that would go in front of the COB to spread the beam more? Would you want to use it on its own or in conjunction with our soft dome or lantern? I ask because we mount accessories using the common Bowens mount, and currently everything we make (dome, lantern, reflector, fresnel, focal spot) uses this. So if you wanted two items such as a "beam-spreading lens" as well as a diffuser then we'd need to come up with a proper way to rig this. If it was just used on its own then it makes designing something a lot simpler for the lens. For instance I could see it clipping to the front of the reflector we include with the Orion 300 FS. Since the 4-way barndoors we include with the fresnel kit also fit on the Orion 300 FS reflector we would try to make the lens not interfere with this. But that just means putting diffusion on the barndoors or punching into a frame, not using a softbox.
So how would you realistically want to use such a lens?
