Paul Overstrom
looking for any tips or diagrams to succesfully shoot an interview with proper lighting and two lights/stand/umbrealls
Im shooting a subject on a black background. I have two lights, 500watts i beleive. and one umbrealla that i can shot the light through and one that i can refelect lifght from.
When i asked my teacer his ideas, he said the following
Hi Paul,
With two lights, try this. Think of the line between the camera and the subject as 0 degrees. Put the main light (with the shoot thru white umbrella on it) 45 degrees off of the 0 line so it is striking the subject from his left side (as you are looking at him). Put the fill light with the bounce silver umbrella on the 0 degree line - essentially above the camera.
Distance between subject an background - in an ideal setting - should be 6-8 feet. Distance between subject and lights is a function of how poerful you want lights to be (therefore what f/stop you will use). The main light should be brighter (technically by about 1 to 2 f/stops) than the fill. You accomplish this by moving the fill further away from the camera (but sitll on the 0 line) as needed.
A third light, which you don't have, would be positioned over the subject pointed down at the top of their head and shoulders.
Just wondering if anyone has anthing to add, or improve on?
And if anyone can post some ideal dvx scene files for an interview, that would help too.
Hi Paul,
