International Repair dilemma
Prairieboy
Ok it is not nearly as big a deal as it sounds but, always a but. My firewire port has crudded out on me. I bought the camera from Rush about 5 months ago. But alas I am in the great land above the US. Can I get the camera fixed up here? If so where (I am in Winnipeg) Or do I have to send it back to the States, and am I going to smacked with duty.
Anybody got any ideas. Thanks
Re: International Repair dilemma
Try Panasonics web site for repair locations. Should be one near you. Call them directly and ask if they will service under warranty. I imagine Rush will reply here too. :)
Hi,
If you bought the camera in the US you have a US warranty not a Canadian one. Most likely the firewire port will not be covered under warranty as there are too many things that you can do to kill it, like plugging it in while "live." It is a myth that 1394 is a live plug and play.
With that understanding it probably would be easier to just have it fixed there. If the board got fried, that is an expensive repair, like $800, if the connector got a bent pin, somewhere in the $200 range.
And yes, Panasonic Canada will fix it, just not under warranty, they will tell you to take the invoice and settle up with Panasonic US. But since the firewire port is so prone to user malignment, its pretty hard to get it covered by warranty, which covers a manufacturer's defect.
Hope this helps,
Jan
Thanks for the clarification Jan! Its great having a Panasonic product guru on board! :)
Sorry the answer is not a happy one prairieboy. :(
Thanks for the Reply Jan
" It is a myth that 1394 is a live plug and play. " It would be really nice if that was a bit bolder in the manual. Damn 800, that hurts.
[quote author=Prairieboy link=board=Links;num=1102129640;start=0#4 date=12/04/04 at 12:37:17]Thanks for the Reply Jan
[/quote]
What is interesting in all of the times over the years I have seen the subject come up on many different cameras, on many different forums, no one ever talks about why the 1394 ports stop working. They just stop working. And nobody says why. If going 6 pin to 6 pin, there isn't much opportunity for disaster, but on 6 to 4 like on a camcorder, the distater is waiting to happen. Hopefully you have only bent a pin and it will be the cheaper fix.
Best regards,
Jan
My job is done here.
(I always show up right in the nick of time.)
Sorry for the bad break Prairie Boy.
Out of curiosity, were you using the DVX for capture? Or were you using DVRack?
Capture!
I do not usually use it, but my wife had the camera I use for capture, so I said to my self, "Self, how bad could capturing one tape be".
Perhaps the problem is my talking to myself!
Or refering to yourself in 4th person. :D
