Hi and sorry if this question has been answered elsewhere. I've done quite a bit of reading though and I'm still in the dark on this one. I have a DVX100B and almost always shoot in 30P. I hate interlaced frames and never use a CRT to view anything. I don't even usually edit in FCP, but I always use it to capture. I have no interest in "film look." All I'm interested in is getting a quicktime file with 30 distinct images for every 1 second.
So that said I have a custom capture profile that usually works well in FCP5. (I have 5.1 as of recently but I don't think anything major changed) In my profile I checked "Progressive" in the advanced box of the quicktime compression dialog. When I shoot 30p I always get a quicktime file without interlacing. (To see if a quicktime movie is really interlaced you have to check "Use high quality video setting when available" in the Quicktime Player prefs). So I'm usually happy.
I recently shot something in 24P by accident. (There is a possibility I shot in 24P Adv but I am almost sure I didn't) Oops. I CANNOT for the life of me get a quicktime movie with distinct frames. Every capture preset I try results in some combination of interlaced and noninterlaced frames. Again I don't edit in FCP and my only goal here is to get the video into some format where there is no interlacing whatsoever.
I read all the tutorials on 24P including the Barry Green DVX book and the Nattress guide, so I understand that the video is 24 distinct frames in a 60i wrapper. When I preview the video in the FCP log and capture window, I can use the software controls to advance the MiniDV tape 1 frame at a time in the DVX, and I see that there are 3 clean frames followed by 2 interlaced frames in sequence (I don't know if this proves that I shot in Adv or not). But everything I am reading says FCP is designed to extract the true 24p video from the camera WITHOUT recompressing / processing (in other words dynamically on capture). I have tried just about every "Easy Setup" and many combinations of custom settings. Basically I am sitting here capturing short clips over and over again.
Again to be clear I'm not necessarily opposed to processing this video a bit to get back to true progressive frames. It would be a bummer but I don't care bc I usually don't shoot this way. But I can't believe everything I try results in interlaced quicktime movies in the Capture Scratch folder. Any help is appreciated. I'm also curious if there is a menu setting on the DVX to show what mode a video being played back was originally shot in.
Since everything I'm reading says "if you shoot in regular 24P just capture as normal and everything will be fine" naturally this is confusing.
