Interlace artifacts in 24PA?
toddburch
Hi all,
Hope someone can help me here:
For some strange reason I'm getting strange artifacting in my 24PA footage that looks like an interlacing artifact when editing in FCP.
Here's what it looks like (these are portions of a frame grab out of FCP):
3 out of the 4 frames look fine, like this:
http://www.cineluxstudios.com/good.jpg
But then 1 out of every 4 frames looks like it has interlacing artifacts, like this:
http://www.cineluxstudios.com/bad.jpg
I'm shooting F6, 24PA, squeeze mode, and capturing via Firewire in FCP.
My capture presets are:
NTSC DV(3:2), 720x480
Anamorphic 16:9 (checked)
Digitizing via Firewire NTSC
Remove Advanced Pulldown and/or Duplicate Frames During Capture From FireWire Sources (checked)
Sequence Settings:
Editing Timebase: 23.98
Using the TARGA Cine YUV Compressor settings at 23.976 fps
This doesn't make sense--it seems like FCP isn't doing the advanced pulldown. Any suggestions?
Thanks,
Todd
Re: Interlace artifacts in 24PA?
Ahh I see HD....Did you just duplicate the already created remove pulldown preset and edit that....?
Yes the capture/sequence presets were duplicated, then edited.
Strange huh?
Absolutely sure, it's the default F6 setting, which was verified during recording.
I wonder if maybe it's because of the codec? I'll test it soon.
-Todd
Fixed my problem, and as suspected the codec was set to 24fps instead of 23.976...whoops!
Thanks for your help Kyle.
-Todd
Bingo that would do it.... Messing around always seems to solve problems...
