Intensity Pro Card - SD P2 24p Preview
rockon81
I have Premiere CS3 which lets you work with P2 data. Hooray. I'm wondering if anybody can shed some light on the Intensity Pro card.
I'm just looking for timeline preview to an external anolog monitor using P2 and filmed at 24p. I've read the specs and it says it only supports standard def. at 525/29.97 NTSC.
Can't I just import my 24p .mxf files into their 29.97 timeline preset and call it good? I recently set up a regular NTSC 29.97 timeline in Premiere and imported .mxf p2 video that was shot at 24pa and the preview looked fine. Premiere does the pull down for me. I dont care if it doesnt let me capture at 24p since P2 is tape less.
If someone has an intensity card, could you do a test for me and see if you can preview 24p footage on the 29.97 intensity preset and tell me how it looks?
We would be using the anolog outputs and we shoot with a HVX.
Thanks!
I use an Intensity Pro Card in my system but I am in PAL-land (thank god) so I can not comment on NTSC media or test it because I do not have any.
FWIW: The card displays anything I throw at it from the timeline SD & HD including native mxf from Premiere.
(Its a great device and it also works with AEFX, PhotoShop)
Shooter, how are you getting your Intensity to display MXF Native from prem, i have to use the presets and theyre anything but native or realtime whats your setup ?
mxf is native in CS3 and the Card has no problem displaying them. In fact they play better and smoother than they do in a non Intensity Preset (Project). Despite the red bar seen on occassion, the playback is usually realtime.
So basically I just use a Custom Preset built on the Intensity Preset.
Ask (or call me) if you need more info (which is easier when I am in front of the system).
oh too 7 for 9 too 3 thousand
AUCKLAND
i was just about to post a new thread when i saw this thread.
I have a question, what differences are there between the DeckLink HD Extreme vs the Intensity Pro? All i want to really do is be able to capture from the A1 straight to the box(high quality) and also use more than one LCD. One for the timeline while the other for previews/realtime display.
I understand i get also high colors with direct capture from camera too? 10bit/4:2:1/2 with XH-A1?
thanks for reading, sorry for thread jacking.
