Intellytech LC-160 vs FalconEyes RX-24
LennyLevy
Just wanted to drop a note in support of the Intellytech LC-160’s. For some time I had both an intellytech and a FalconEyes RX-24 which is similar but cheaper. Recently i sold the FalconEyes and got a second Intellytech even though it cost a bit more. I don’t want to knock the RX-24 because I still think its a damn good light especially on a budget, but I chose to get a second LC-160 for a couple of reasons:
1- Probably most important to be honest is just the small carrying case that makes it easy to use without having to transport in a soft bag that’s over 2’ long.
2 - More accurate daylight temperature: The Kelvin readouts on the controllers of both units seem to be higher than the real Kelvin output of the lights. So while the controllers might say 5600, my tests show the lights are really putting out something closer to 5100 or 5000. Since the FalconEyes controller only goes from 3000-5600 you can never really get a full daylight 5600 out of the light. (By the way this is pretty common with Daylight LEDs.) The Intellytech however will go all the way to 10,000K so you can easily get true 5600 and cooler if needed.
3. Color temp accuracy. Originally I found both lights to be close to perfect color but slightly off. The Intellytech seemed to be around 1/8 Magenta and needed a 1/8 Green gel to hit the spot. The FalconEyes was the opposite - about 1/8 Green , however for some reason a 1/8 magenta would overcorrect so it was easier for me to balance the Intellytech.
However when I got the second LC-160, Intellytech had changed the LED’s a bit and the color now is spot on.
4. The intellytech feels to be more solidly made though I didn’t have any trouble with either light.
5. Support: Intellytech is US based and I had quick response from their support when I had a couple of minor problems. I don’t know what FalconEyes would be like but at NAB I found it difficult to even communicate with their salesman because he barely spoke English. I suspect it will always be harder to get support from China.
Incidently I used the Intellytech with the 1/2 china ball adapter recently to light a panel discussion of 9 people in a semicircle and it was the only key light we needed. The light was absolutely even in all directions underneath. Around 32 footcandles at 5600 with the people about 8’ away. My gaffer was very skeptical until he saw it up.
lenny levy
Lenny, what gels do you use to correct the LC-160? Do you use a custom cut 24" x24" 1/8 plus green you fold into the case? I'm not even sure who offers 1/8 plus green except the Lee 278 which comes in the long rolls...?
I like the LC-160 but I abandoned the Intellytech case because it's too hard to jam everything in there, and I can keep the softbox and grid assembled and semi-folded in a larger but still manageable case, and that really saves on assembly time.
The colour shifts that lesser LED panels have is not acceptable today when there are alternatives that just works without any correction. That what steered me away from the Intellytech.
I just use the standard lee sheet 24x21 and just stuff it in there. The fit isn't exact but Since the light is so diffused it doesn't matter. Its perfectly serviceable. The recent LC-160 seem to have more exact color to me and the alternatives really go up in price. I haven't had any trouble stuffing everything in the case but I do understand the time issues with setting the lights up. I used some velcro to keep my power supply and controller always connected and that saves some time but finding a case thats 2x2 isn't easy and the convenience of the small case is great for my working style.
I still have some Falconeyes 12x18 RX-12's that I use mostly as backlights and for those I got a Pelican case off eBay and keep them semi assembled so its quicker to set up. I do the same thing with their power supply and controller. The routine is still slower than setting up a one piece light, but the payoff is worth it.
My one gripe mostly for the smaller back lights is I wish they had a remote controller. I don't need it for the 2x2 as I'm always near enough to the controller when shooting.
Falconeyes has a new remote, the rc6 that appears to control the 12td and 18td. Don't own this so I can't check but I am looking at these lights and am going to try them. Remotes make life so much easier when you work solo.
Was there a difference in max brightness of the lights? I just picked up the rx24tdx as I'm on a budget
No significant difference in brightness. RX-24 is a great deal if your budget is tight.
Thanks for the tip about the RC6. That's a big deal to me and my only negative on the lights because I often use them as backlights , frequently when I'm short handed.
Hey Scotchtape, Thanks very very much. I bought the RC-6 and it works like a charm. Just what I wanted with those lights.
Awesome, you're very welcome! I'm about to order one. I finally got a meter to test LEDs. I've been using the fl3060 panels and turns out they are pretty bad. Shame cause they set up faster than these lights, I wish they sold the frames separetely, like the westcott led cine frame instead of the x bracket. I have a RX 24 and 18 now, waiting for remotes to come in!
