Industrial High Bay Flo Lights
notharrylume
Has anyone used an industrial highbay fluorescent fixture for set lighting?
Here's the idea: Lithonia, among others, makes an 18"x48" 6 lamp T-5 54W T5 fixture (IB 654L). Drillspot advertises it for $230 without lamps, which you can get for about $15 a piece or another $90 dollars for a total of $320.
The postives are lots of light at a good price; plus being a 4' long fixture means that it will be a softer light than the typical 24" biax fixture of the same wattage. I imagine it will be brighter than the biax type also because the lamps are more spread out and don't block themselves as much. The $15 T 5's appear to be CRI 85.
The negatives (compared to the Coollights biax, for instance) are that it needs to be adpated, at some price and effort. At a minimum it needs a mounting solution, and then it could use a grid and/or barndoors, although it is available in a "narrow beam" configuration.
I have not ever tried this but I could definitely see it working, as long as you're okay with having somewhat harsh light and you don't make the actors look into the lights (or, alternatively, if they have to, do a shot where it's okay for them to close their eyes).
