IndiFOCUS question
FatBird19
I've been looking at the indiFOCUS that's advertized on this site occasionally.
Can this thing be used with 35mm adapters? The only reason I would be concerned is because the rubber wheel seems really large, like it'd get in the way of other functions on a 35mm lens.
any thoughts? can anyone who has actually used this say anyhting good about its performance?
From what I can see from the plans the large rubber wheel can be removed, so, you may have to come up with or encourage the inventor to come up with an additional wheel that would function on a prime lense in narrow spaces. I can see that basically it's a good product and will considering getting it myself. You've just got to work it a bit!
For lens adaptors I am introducing a geared version. As the indiFOCUS is modular in nature, the friction wheel removes with one set screw by an allen wrench (included), and the geared module replaces it. It includes three lens gears. The friction wheel is also included. The price is $389. I'm conducting trials on it now, so I expect to intro it by Feb. 1.
A note though: If you're only using the stock lenses, then the indiFOCUS is the way to go...at a savings of $90. And because it is modular, you can upgrade to the geared version for the difference in price, $90, at anytime.
